ES300 trunk light
Old 04-20-13, 05:45 AM
ohsimachi
ohsimachi's Avatar
Default ES300 trunk light
Just in case there is anybody still out there that is living with the tiny stock trunk light and doesn't want to re-wire the trunk adding lights.
This pic was taken in a pitch black garage with no flash on a fairly crappy cell phone camera.
its a 36 surface mount LED panel with the 194 bulb adapter in the stock housing with the stock lens cover.
total cost: $3 took about 3 minutes.
Old 03-12-14, 06:54 AM
Alexbenz
Alexbenz's Avatar
194 fits into the trunk holder? mine looks like a skinny festoon fuse looking bulb
Old 03-16-14, 05:18 PM
PDXLex
PDXLex's Avatar
Can you elaborate more on this? Do you have any part #'s or a write-up you could do? My trunk light is dead in my '00 ES 300. I removed the strange looking bulb and bought it to my local auto parts store, but they had nothing even close. I was looking for an alternative to driving out to the Lexus stealership.
Old 03-18-14, 03:39 PM
Cosanostra
Cosanostra's Avatar
It depends on your ES generation and how / where you want the leds mounted. My 1994 used a 194 bulb, so I was able to use a modified (had to shorten it) 194 plug adapter, along with an led board and some hot glue for mounting. It makes a big difference in lighting and has been working fine since 2010. I'm considering adding an additional led board to the underside of the speaker deck since the current light is easily obstructed when stuff is in the trunk. I found that 4000 - 5000k color temp worked best for a nice bright white rather than the 6000k bluish leds.
Attached Thumbnails ES300 trunk light-original-light.jpg   ES300 trunk light-led-panel-hot-glued.jpg   ES300 trunk light-led.jpg   ES300 trunk light-brighter-trunk.jpg
Old 03-18-14, 04:01 PM
Cosanostra
Cosanostra's Avatar
Looking on the Sylvania bulb guide site. http://www.sylvania.com/en-us/applic...s/lrgmain.aspx it shows the 2000 ES300 trunk bulb is the DE3021. There are many direct plugin replacement LEDs available at the various led bulb dealers on the web. Hopefully someone can recommend a good one for you. Good luck.
GS408
SC- 1st Gen (1992-2000)
04-07-17 07:07 PM
Power6
04-20-13 06:40 PM
Gchutes
02-22-12 03:18 PM
TheAirman
HS 250h Model (2010-2012)
01-06-12 07:01 PM
chicagoblknazn
Lighting
18
10-12-02 12:15 PM
Quick Reply: ES300 trunk light
