Uh oh??? Not in neutral when turning crank!
2000 es300 with 190,000.
I'm changing my timing belt, water pump, pulleys, etc... for the first time. I found TDC with no problem. Took a break and was reading somewhere that I should have put the car in neutral!!!!
Did I damage anything?????
The position of the transmission gear selector has no effect on the job you're doing, zero. Where did you read this anyway? On a manual transmission yes, it would prevent you from turning the engine, but not on an automatic like your car.
d2gs3
07-07-05 08:07 PM
