97 ES300 check engine light
The test came back PO135 02 heater circuit bank 1 sensor 1. My question is if I buy this and install can it still be other problems? Car has 250,000 miles and I hear a small exhust noise like maybe a gasket? Thanks!
Yes, it can be other components that cause your P0135 as that circuit goes through the throttle position sensor, relays, fuse, etc. Bank 1 sensor 1 is the O2 sensor between the engine and firewall. The sensor is not reaching temperature as quickly as it should.
AndyG
23
04-15-22 07:36 AM
imAC
04-17-13 07:19 PM
ivie08
RX - 1st Gen (1999-2003)
08-21-10 10:24 PM
