issue with heat after change coolant
this weekend, I changed coolant, on #3 Drain plug(back engine), the bolt should have another small little bolt, but it doesn't have it, so I try to counter clock turn the bolt, but it only moved few inches, I am afraid break the bolt, so it didn't drain any old coolant, even I flush with Distilled water, still nothing comes out of it, but since the #1 and #2 drain plug drain a lot of coolant, I decide that is ok to finish the rest of project. But bothers me why?
and when I do the test drive and this morning to work, about 35 mile on the highway, even in local, I Noticed the when no heat or air condition turned on, when I switched to air from outside to inside button, I felt a lot of heat come out of it, when I switch to air circulation within, the heat is gone. Why?
I guess I have never noticed. may be it is always like this.
any idea?
Thanks
any idea?
Thanks
Hi MrBooby,
How are you? I drain the radiator plug and the plug near the oil filter, but not the one in the back because I cant get the coolant out of the plug, try turned the bolt counter clock, but it only moved 2 inches. But if u turned the heat and air condition on, it worked, is just when u have nothing turn on, the on the outside to inside **** on the dashboard, then I can feel the heat, if you turned the inside to inside ****, act normal, no heat coming out.
Thanks
Thanks
