How to clean IAC Valve and MAF sensor?
Old 05-28-13 | 05:32 PM
lexy2013's Avatar
lexy2013
Cool How to clean IAC Valve and MAF sensor?
Hey all
would someone be able to give me a heads up on how to clean the IAC valve and MAF sensor properly on a gen 1 ES300?
Thanks
Old 05-29-13 | 02:59 AM
lexy2013's Avatar
lexy2013
anyone?
Old 05-29-13 | 04:14 AM
StuckInVA's Avatar
StuckInVA
by first generation es300 I'll assume you are referring to the 1mz application as the 3vz did not utilize a MAF sensor.
As far as the MAF sensor cleaning goes, I believe it is the same as almost every other MAF sensor: unhook it, spray it with the MAF cleaner, let air dry, reattach
IAC valve. Hope this helps some
Old 05-29-13 | 04:45 AM
lexy2013's Avatar
lexy2013
IAC valve. Hope this helps some Camry Idle Air Control Valve Cleaning - YouTube
hey bud yeah sorry mine has the 3vz-fe engine ??
Old 05-29-13 | 07:18 AM
StuckInVA's Avatar
StuckInVA
So does mine. As I mentioned before the 3VZ-FE does not use a Mass air flow sensor to meter air it instead uses an air flow meter. it is the silver housing attached to the top of the filter housing. What's really great it you don't need to clean it.
You also do not want to attempt disassembling it. there are two screws on either side of the connection port, if you remove these and pull on this connection you will most likely ruin this part. You can see the inside here. https://www.clublexus.com/forums/es3...ml#post1385991
To clean the Idle air conrol valve you can simply unbolt it and clean it up with some throttle body cleaner. You'll probably want to replace the gasket. Which I believe is part no. 22278‑62030.
Old 05-29-13 | 07:19 PM
lexy2013's Avatar
lexy2013
the IAC valve sits right under the throttle body right? does that mean i have to take off the whole throttle body and some of the inlet manifold too?
Old 05-30-13 | 08:34 AM
StuckInVA's Avatar
StuckInVA
It doesn't sit under on the 3VZ. It sit on the side of the manifold right after the throttle body on the side that faces the rear of the car. You have a hose that runs right to it coming off of your main air cleaner hose. This is what it looks like http://www.rockauto.com/catalog/more...751&cc=1387021
Old 05-31-13 | 06:27 AM
lexy2013's Avatar
lexy2013
tnx for the heads up bud
Old 06-02-13 | 05:36 AM
lexy2013's Avatar
lexy2013
hey bud i was pulling the iac valve apart and when i wasnt paying attention these two black washers fell out not sure from where though?
i got the iac valve here with me just not sure where the washers go so i just put them in the bottom of the black casing
Old 06-02-13 | 06:57 AM
lexy2013's Avatar
lexy2013
anyone know where these two washers are meant to be? i wasnt paying attention when i pulled the thing apart
Old 06-02-13 | 07:21 AM
StuckInVA's Avatar
StuckInVA
To be quite honest I didn't take mine that far apart. It looks like the only place they really could go is on the end of that shaft though.
Old 06-02-13 | 07:29 AM
lexy2013's Avatar
lexy2013
they dont fit though haha
Old 06-02-13 | 07:35 AM
lexy2013's Avatar
lexy2013
wait i think i know where the two washers go no they go on the other end that seals the incoming air (valve end) but why two washers and not just one
actually im missing the bearing which probably explains why
i should look where i disassembled for some more clues
Old 06-02-13 | 12:21 PM
EEngineer's Avatar
EEngineer
oh man...i took one apart before and realized it's not really meant to be taken apart...
Old 06-02-13 | 07:22 PM
lexy2013's Avatar
lexy2013
cleaned IAC valve and i still getting clouds of white smoke from exhaust bit of water drip upon start up exhaust fumes smell ridiculous... engine idles awkwardly rpm rise then drop
no coolant loss or decrease in level ???
Jay hall
RC - 1st Gen (2015-present)
05-23-16 07:46 AM
calticboy
RX - 1st Gen (1999-2003)
07-06-11 06:27 AM
1993Ls400s
13
10-02-08 12:36 PM
UberNoob
Maintenance
08-27-08 05:35 AM
95ARISTO
GS - 1st Gen (1993-1997)
12-11-06 07:17 AM
Quick Reply: How to clean IAC Valve and MAF sensor?
