What size is a 98 es300 injector? I have 2 bad ones
1mz should be 280cc/m but knowing the size won't help u at all.
u can get same flow rate injectors but they will behave completely different from stock ones.
just go for a junkyard run and get some used ones. have them cleaned and pop them in.
I think my injectors are starting to perform poorly. Don't think they have completely stopped working as of yet because I don't have a CEL.
Was just wondering if you could describe the process by which you have them cleaned EEngineer. Do you have someone locally that does this or do you have to send them off?
The reason I ask is it's really hard to find someone to do anything to a vehicle semi professionally out here in the country
I just need to know if sending them off is my only option or if I just need to look harder for a shop.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
2UX31 YM
12-10-11 08:54 AM
