IS 300 Wheels on the ES
IS300 Wheels 01-04 are 5 spoke 17x7 50 mm offset. They fit without any issues however tire sizes must be 225/45 or 215/50 and smaller or you'll see rubbing issues needing spacers and or fender work or both. If you get spacers get hub centric or bolt on spacers the cheap ones will screw you in the end. Most 235/45's will fit in the back without rubbing the strut towers some 225/50's won't fit out back due to the bulge causing strut rub but will fit up front. However they will hit the plastic fenders on HARD turns or bumps 225/50's will rub out back even with rolled/pulled(in my case hammered fenders). 235/45's may fit all the way around with no rubbing period. By the way if you want a funky look keep your stock lugs, I'm sure the IS300 or aftermarket lugs will suffice just replace with similar design if going aftermarket. None of the sizes listed have put my speedo off by more than 1.5 or so at 60. There's a pic of them on my car 225/50's up front/ 235/45's out back with no spacers.
That's is my experience with a 2es with proper alignment and decent struts. The same should likely apply to the 3es for the most part.
I know this has been over at times but now straight up post on it I don't think. Maybe this could be stickied since so many like to put theses wheels on the es later guys, btw what you guys think? Look pretty good?
This setup is posted time & time again in the Official ES Aftermarket/OEM Wheels Thread
What size tires did you have that needed 5mm spacers? Or was the wheel it self gonna hit the 3es strut?
Muti007
08-14-14 06:50 PM
TORTOISE
09-12-07 02:34 PM
