VSC,Trac off,check engine light on with code p0793
Hi,i have a 04 lexus ES330 with the vsc,trac off and check engine light on,along with code p0793 (intermediate shaft speed sensor "A") which speed sensor is that? Im told theres more than one and i dont want to buy the wrong one.Any info with be appreciated. Thanks in advance!
Order it from amazon. They sell OEM sensor ($70) + the tool ($7) ... much cheaper than dealer. You should read the feedback under the product description. People are posting their car code and the sensor for you to verify if you have a same problem like you have or not..
@Peter,It turned out it was the one on the top under the air filter compartment.One of the cables was broken and i repaired it,erased the codes and they havent come back. Thanks for the info on amazon,those prices are cheaper than the ones i saw on ebay. Also when i fixed the wire the vsc and trac off lights left as well as the check engine light. I almost bought it online yesterday and something told me to wait and check the part first. Thank god i did. Thanks again for your help
Any pictures? The same indicators also just came on on my '06 ES330. Would like to also fix myself. I don't want to spend more than I have to this Christmas. It's also a P0793 code. if I wanted to buy the part, would it be
Manufacturer Part Number:
89413-08020, 89413 08020, 8941308020
or
Interchange Part Number:
917-603, SC153, SN7138, 090-603, AM-28071911?
or
