installing remote starter - need help with a-pillar and wiring
Hi all,
I'm installing a remote starter in my 2004 ES330 and need help with removing the inner A-Pillar trim to run the antenna cable and location of wiring harnesses.
I searched and came across two posts related to A-Pillar inner panel removal but no details provided other than pull it hard. I don't believe this is the case. I think there is a method as to where you pull and in which order you pull. Does anyone have any comments or WIS/Service info on removing the panel?
The same goes to the wiring harness. IN the documentation i've come across, including Googling online, it says "ignition harness" but don't know specifically where other than it would be in the general vicinity of where you put the key in.
So would greatly appreciate any info on removing the A pillar interior, and showing locations of where the harnesses are.
THanks in advance.
THanks in advance.
kidoekid
03-02-09 08:38 PM
Tranman
10-03-05 03:26 PM
