ES 300 Need advice
ES 300 Need advice
i bought a 2000 es 300 with 170k on it sharp clean dealership maintained. 2 nights ago i started it and put it in drive made it about 20 feet then it died it rolls over but wont start.... i can't hear the fuel pump run when i turn the key either. so was just seeing if there might be anything else i could try before i replace the fuel pump and it not even be the problem.
thank you
thank you
thank you
thank you
Remove the back seat and energize the fuel lines by manually hooking up a 12V power supply to the fuel pump. You will need to know which pins to use. If the pump runs, you can then try starting the car. If you're not comfortable doing that, you can inject a flammable liquid(carb cleaner) into the throttle body/intake plenum while cranking the engine. This will also tell you if it's a fuel issue.
If you determine that your fuel supply is okay, after those tests, you may proceed onto testing your spark. This is a bit easier. You will need to remove one of the coils with a spark plug attached. Then lay the whole thing on the engine block and stand back. Have somebody crank the engine and see if the spark plug is working.
Lastly, I would check the compression and timing. Oh and a weak battery may also be an issue.
Re:
took off the I.A.C.V cleaned and re-installed fixed the problem thanks for all the help and advice hope this helps anyone who has a similar problem. Again thanks
joshana12
10-29-14 02:29 PM
