ES330 side mirror not moving
I have a 2004 ES330. The passenger side mirror no longer moves in any direction - neither manually via the console switch or automatically via memory settings (I moved the mirror to a different location first). For the automatic setting I did confirm that settings were in place first - my drivers mirror and seat moved after I selected the #1 preset. Also, when using the console switch I do hear a click, from somewhere behind the dash, when pushing on a direction button. I took the side mirror assembly apart, but without an assembly/wiring diagram I wasn't able to figure out what wires I should probe to see if they were getting power or if I could manually supply power to the actuator to see if it would move.
1) Any suggestions on what might be wrong? 2) Any pointers to the side mirror assembly/wiring diagram?
Thanks in advance,
Dave
Thanks in advance,
Dave
