Exact location of a/c fuse?
Can anyone tell me, where the a/c fuse is located? I thought it mention on the fuse box located right next to the battery, but when i tried looking for fuse/where it is inserted to, there were none.
What is the problem that you are experiencing?
It would help if you can specify the year and model of your car, the profile says you have a 1999 GS300, while this forum section is dedicated to ES models. Here is a link to a GS section, if the answer below won't help, that ill be the place to go.
Here is a Fuse Diagram for yous car, you need to check a 10A HEATER fuse. As for where to get fuses, I usually go to a local junkyard and pull as many of them as I need, that way I get a lot of OEM fuses for peanuts. If you don't have access to a junkyard, get some quality fuses from parts stores, don't cheap out on ones from Amazon, their housing melts faster than the filament, which can cause some dire consequences.
Hope this helps and best of luck!
