1992 es300 questions on dash lights, misfire
my car has had a misfire since i got it a few weeks ago. since then it developed a horrible oil leak, which i replaced the oil pressure sending unit and oil filter housing gasket to start off, fixing the leak. the misfire only happens sometimes. like itll go two days without doing it, and then the third and fourth day it comes back. and sometimes the engine shakes harder than other times? so maybe its not even a misfire. but if it is, i was told there could be oil getting on the spark plugs (which were all just replaced as well as plug wires, valve cover gaskets, and distributor cap in the last year) so.. is that a possibility that thats whats causing it to misfire? if so thats okay cause spark plugs are easy to replace right?
and also, the needles on the rpm gauge and mph gauge dont light up anymore and so its black on black and hard to see what the speed or rpms are. do i have to replace the whole panel?
To check the intake tube just start at the air filter housing and follow the tube all the way to the throttle body lookign for any cracks.
ALso if check engine light is on you wll have to use the OBD 1 methods to retrieve the codes.
Keep us updated
njamal
10-06-03 12:02 PM
