Just an idea and some thinking aloud
Don't beat me up here but I just wonder what would happen if you put a little boost into the air assisted injection system? One would have to draw the air into some sort of pump or small blower from after the MAF somehow and it would need to be switched off at idle and have a check valve to prevent blowing back through the IAC but I wonder if one would gain anything here. I am just taking a "what if" approach to this but I would love some educated input here. I would like to think that this sort of thinking is how good R & D come to be .
Don't beat me up here but I just wonder what would happen if you put a little boost into the air assisted injection system? One would have to draw the air into some sort of pump or small blower from after the MAF somehow and it would need to be switched off at idle and have a check valve to prevent blowing back through the IAC but I wonder if one would gain anything here. I am just taking a "what if" approach to this but I would love some educated input here. I would like to think that this sort of thinking is how good R & D come to be .![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Not quite... This is simply increasing the velocity of the air flowing past the injector tips making better fuel atomization occur. This is a good read to understand what I am talking about.
http://bio.souz-96.com/Lexus/RX300_R...ESCRIPTION.pdf
That is almost what I mean. My theory is that having a little pressure in the air assisted fuel injection system while the throttle is open more than say 40% or when vacuum in the plenum and manifold is low would continue the effect of high velocity air in the air assisted fuel injection system even at full throttle thus resulting in better fuel atomization and more power. The air assisted fuel injection in the 1MZ relies on the vacuum in the plenum being greater then the vacuum at the injector nozzles thus causing the air regulated by the IAC to rush and swirl in the injector tips in order to benefit fuel atomization. When the throttle is open more than 40% the vacuum begins to equalize and the effect is lost. So that is back to my idea which is essentially to force this system to continue to work through the entire engine RPM and throttle range. Do you think it will result in any gains? I think I just have to try it and find out.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
That is exactly what I mean!
But I will never buy a BMW. I am just thinking out loud here. I can never leave good enough alone and I am a bit of a Wicked Tinkerer as they say. Extension cords are for plugging my tools into not my toys. Also I think I have an idea of how to try my idea. I think I could just build a small scoupe into the port in the TB where the IAC inlet is. I have access to a lot of aircraft tools and materials so this should be easy.
vanquish2
08-26-11 09:10 AM
TURBO819
Performance & Maintenance
09-26-10 04:07 PM
