"Replace bulb" dashboard light is on, but...
Check all the turn signal and brake light lamps, does one seem dimmer than the other? If so, you may have corroded or loose contacts and that will cause the replace bulb warning light to falsely come on.
Don't forget to check the 3rd brake light!
And don't forget the small taillight bulbs --not even sure if these trigger the warning though.
You can also narrow it down a bit.
If the light comes on right after you press your brake pedal, than its a problem with one of the brake related bulbs, if not, than its one of the other bulbs.
Phil
Phil
To access it, go inside (backseat) and pop up and remove the 3rd brake light housing, disconnect the wiring harness and replace your bulb, reinstall!
soyhead
02-08-06 04:39 AM
