I need a repair manual on 96 lexus es 300
If anyone can help I need some direction to fix power steering pump hose that is leaking
I have to spend money on fluids every other day to keep from over heating.
If any help give would be such a life saver to my pocket.plus the leeking fluids everywhere
I park.
Please and Thank you
I park.
Use this one here, it's for the 94-96 Camry, but it's essentially the same thing as the Lexus. 94-96 Camry Repair Manual
Have you tried "Lucas" power steering fluid? I have had the same problem. Smoking under the hood, all hoses are leaking. This stuff slowed down the leak tremendously. Then again it is only a temp fix. I have found the high pressure hose to be expensive, so I tried this stuff. Its worked for over 6 months.
This is the exact reason I got my '96 for my daughter kinda cheap - ps hoses leaking. I got the hoses at Autozone cheap (<$200 for, I forget if it was 2 or 3, high pressure hoses) and paid a local shop <$200 to put them on (great deal there). Find a local indy who'll use your parts to fix the car if you want to pay to fix it. I would not dump any sealer stuff in there - won't work for cracks in the hoses.
PolishDude
03-01-23 09:05 PM
farklspark
12-02-16 05:13 PM
