Another P0441 Thread
Originally I had a P0450 code and purchased the vapor switching valve and replaced that. The code went away and then the P0441 code appeared with a pending P0446 as well.
Looking around I've found that there are two similar valves, the Vapor Canister Purge Valve and the Vacuum Control Valve.
Could it be possible that I replaced the valve with the incorrect one? For the P0450 code I replaced the valve with the VCPV. Should I have used the VCV instead?
-WonderBread
-WonderBread
mpm86
GS - 1st Gen (1993-1997)
04-05-14 09:56 PM
TriniLex
11-13-12 11:28 AM
