need help 2001 es300 problem
heyy
im new here , im thinking of purchasing a 2001 es300
there 2 problems with it , one is theres a misfire and the car always struggles to start
and 2 the is running lean , and when i drove the car had no pull or accelaration it was lacking serious performance
what can be the issue of this ?
If it's doing all that then it has to have codes, start there. Could be a failing coil, could be a failing injector, could be unmetered air coming in behind the MAF. You need a code to tell you where to start.
Could be bad gas if it has sat for a long time without being driven. Definitely need to get a look at any codes it may have in the computer as mdbrown mentioned. Did you look under the hood? Might be a whole host if things wrong that you can see by peeking under the hood.
SC300_704
06-16-09 07:16 PM
