Two annoying problems to my ES
#31
First option, you can try to find hood that is same color on ebay, local junkyard, maybe post in "wanted" perhaps someone's parting out a car and will have a spare hood.
Second option is to have someone paint it for you, maybe check local craiglist and see if someone paints at home/their own shop and will paint it for you inexpensively compared to body shop.
Third option is you can have maaco paint it for you. If you do decide on this option you should buy paint yourself, I would strongly recommend PPG Deltron 2000 as it will have closest match. They would have to blend paint into both fenders. One pint should be enough. Make sure they prep hood very well, sand it all down to bare metal, epoxy it/urethane primer and then paint/clear coat it.
When I was driving around town, often.. some Hispanic waved at me and ask if I want to have them fix my car.... but how can i trust those people?
For the Maaco part, its always better to buy paint ourselves right? what kind of paint will they use?
#32
I replaced the rotors on my 03 ES300 and I remember paying around $40-50 per rotor (non-OEM). If/when you do replace the rotors make sure you throw some paint on them too. Mine started to rust after a month or two.
As for your hood, since you are short on cash and looking to sell yor car in the near future, I would give it a thorough sanding and paint it with a spray can or two.
#33
Appreciate for you advice!
I wish I know someone who live within 100miles .. probably i can learn a lot from him (mechanic stuffs, etc...)
I do have a thousand dollar in my pocket for fixing the car, but not sure if it worth fixing then sell it.. or just sell it like this
#34
#35
Look for local PPG automotive paint distributor.
http://www.ppg.com/coatings/refinish...e=17&Zip=99208
#36
Thank you for all the detail info, mitmaks!
#37
Since my front bumper is crack, i think i should replace it if i am going to paint the hood , so that the car will look a lot better.. but the problem is, the bumper is two tone, and that will cost more to have the 2 color painted on the bumper..
I calculating whether I can get a car by the end of this year, if not, then i will fix my car and stay with him for another year
There are some weird noise in front of my car while in low speed, like metal hitting metal [ALL assuming driving on a relatively rough road, not like Rally, but not smooth]
1) "cling cling" sound while in low speed but not stepping on the brake or braking
2) "Crank Crank" sound when driving in low speed + breaking
For Q1, is it an engine mount problem? the previous owner changed the engine mount, probably60k miles ago
Heres what I found about diagnosing the mount problem online -> "So if the mounts are broken, you're likely to feel more vibration from the engine, you might hear the engine bump around when you go over bumps, and when you step on the gas, the engine literally will try to lift up out of the engine compartment."
I don't know if I really got that feeling while driving but my car won't shudder while driving (i don't accelerate my car VERY fast..)
Sorry if it makes no sense to you
#39
#40
#41
I hate myself now.. I don't even have a friend who knows how to do maintenance on their car
does it mean i should sell it , then get something else???
Let me record a video for annoying sound and low idle when i go home tonight or tomorrow
btw, how can you tell whether is the ball joint or the tie rod?
Thanks for answering !!!
#42
Can't get a good quality video ..
perhaps i need to use a voice recorder...
So sad today, when i was driving around LA, the check engine light comes out ...
the driving feel is fine, transmission shifts okay... not sure what happened
I am going to a business trip with my boss tomorrow, hopefully i can bring him to see a doctor soon..
