Running a 15% LTFT
Old 10-27-13 | 04:03 PM
MikeLex's Avatar
MikeLex
Default Running a 15% LTFT
My ES runs consistently a 15% LTFT on both banks B1 and B2, that is within the 20% trigger point for fuel trims according to Lexus (at least for generation 3), but a little high to me. It has no issues at all (maybe the gas mileage in city driving could be better, but that's a controversial subject). So.. ., guys, please chime in and tell me your numbers.
Old 11-14-13 | 07:21 PM
coffee4000's Avatar
coffee4000
The LTFT 's on my Toyota Camry are 7% on Bank1 and 13% on Bank2.
But it seems that yours is on the high side . . . approaching 20%. This means that you have a "lean" condition. This means that you have too much oxygen in the air/gas mixture and the computer is trying to compensate by adding gas . . . and adding gas . . . and adding gas.
It might mean that your oxygen sensors are starting to show their age and not performing that well.
If they can't actually determine the air/fuel mixture by analysing the amount of oxygen in the exhaust, they could be telling the computer to keep adding gas.
Or you might have a vacuum leak.
I am curiouis as to what LTFT's other have.
Old 11-15-13 | 02:36 PM
MikeLex's Avatar
MikeLex
[QUOTE=coffee4000;8237462]The LTFT 's on my Toyota Camry are 7% on Bank1 and 13% on Bank2.
I am curiouis as to what LTFT's other have.[/QUOTE
Thanks for the reply. I think I might have a very small vacuum leak because the LTFT's of both banks drop to about 4% in less than a minute under load/acceleration. It puzzles me.
Old 11-15-13 | 08:13 PM
Hayk's Avatar
Hayk
Now I wanna know what my fuel trim numbers are
Old 11-16-13 | 07:54 AM
MikeLex's Avatar
MikeLex
And so do we I suggest you to connect the scanner to the OBD port and monitor the LTFT numbers while driving, especially under load and heavy acceleration, but BE CAUTIOUS: do it only on a traffic-free road!
Old 03-22-14 | 02:27 AM
Hayk's Avatar
Hayk
Finally got a chance to do that, except I never went to heavy acceleration. Chasing a bad odor on cold starts. Check it out.
https://www.clublexus.com/forums/es3...bad-smell.html
Old 03-22-14 | 03:28 AM
PuReChaos's Avatar
PuReChaos
My LTFT on both banks is 1% That could mainly be due to how under used my engine was prior to buying it as i'm just nearly at 54k.
petek22
03-11-24 10:44 PM
GRPFAN
12-11-13 01:10 PM
MoJoMan
31
08-15-11 11:06 PM
LexLuger31
14
07-19-11 09:05 AM
