Lexus es300 headlight
I am importing an ES300 96 into France and before it can be registered I am told that the headlights must be changed as the side parking light and indicator are the same bulb. What they require is 4 bulbs in the headlight thereby separating indicator and parking light. (European rules). Does anybody know where I could source the correct headlight.
Thanks DPM
Thanks DPM
Can't you just add a separate side marker light of some sort into the fender, and than re-wire the electrical connection?
Another possible option would be to mount some appropriate lights where the fog lights would normally be.
Unless I'm missing something, it's probably a much simpler solution.
Phil
Phil
02es300lex
10-15-14 04:29 PM
