2ES temp gauge and idle question
Old 12-14-13, 01:05 PM
94LexES
94LexES's Avatar
Default 2ES temp gauge and idle question
First question is: Why does my temp gauge go down when I'm on the highway then it comes back up when I'm not on the highway?
Second: My car idles at 1K once it's warmed up, is that normal?
Old 12-15-13, 10:05 PM
DJPsystems
DJPsystems's Avatar
Thermostat may be stuck open.
Old 12-18-13, 04:51 PM
94LexES
94LexES's Avatar
great... lol I thought it would be the coolant temp sensor?
Old 12-18-13, 04:53 PM
hypervish
hypervish's Avatar
I agree, sounds like the thermostat is stuck open a bit. When you say the temperature goes back up when you are not on the highway, you mean it goes to the middle correct, it doesn't overheat?
1,000 rpm is too much if it fully warmed up, however i suggest waiting till you have replaced the thermostat to tackle that issue. The ECU may be trying to warm the engine up because of the stuck open thermostat.
Old 12-20-13, 07:50 PM
94LexES
94LexES's Avatar
It doesn't even go to the middle at all, it touches barely above the second to last tic even after long trips. There's no overheating issues at all.
haulin79
32
05-24-24 12:31 AM
LoveSCs
Performance & Maintenance
07-11-16 03:50 PM
Vtur
02-14-12 07:48 PM
4thHorsemn
SC- 1st Gen (1992-2000)
12-17-10 12:07 AM
fordsvtmfl
Performance
06-02-09 05:06 PM
Quick Reply: 2ES temp gauge and idle question
