Any Advice for a "Newbie" Lexus Owner?
Not much of an advantage other than brightness and they tend to last longer, however, I did them because I just don't like the look of stock bulbs. Definitely not something thats required to do but it is a pretty cheap upgrade. Below is the ones I changed first because the stock bulbs didn't give enough light.
Also forgot to mention, thanks to hypervish, I also upgraded my stock radio to include bluetooth! It was hands down my favorite addition so far.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I am seriously considering the "Sky Blue" kit from xtralights.com. Entire kit (including trunk light) is $79.95 + tax + S&H. Not bad.
Welcome!
One easy and inexpensive improvement is to replace the parking lights, the outer small bulb at the edge of the headlight. Instructions are at carcarekiosk.com, it's very easy to access them through the wheel wells. I replaced the yellowish, dull bulbs with bright white 20-SMD LEDs.
www.youtube.com/watch?v=Mm5CSI-FOeU
And here is Megafast's car:
www.youtube.com/watch?v=8lLkUDL3h18
Ouch, isn't that kind of steep for a 2002 car? Is that what they go for in your area?
It'll match the HID's nicer too.
I kinda like the look of HID headlights + yellow fogs though.
Looking forward to some pictures.
I installed LED strip lighting in mine, this was before I replaced the puddle and map lights with LEDs:
+1
+1
Look's great!
Welcome!
Funny you should mention the parking lights. Last night, I noticed the parking light on the passenger side is out. It will be replaced this week (at no cost to me since I've owned the car less than a week).
They were originally asking $11k (which I know is WAY overpriced).
Edit to add: Fully loaded, EXTREMELY clean, I'm the 3rd owner, clean CARFAX (0 accidents, don't know how much weight to give that) and service records up to 120,558 miles (car currently has around 127,500).
To post a pic, I clicked the icon and it's asking for the URL, but I don't have one.
I'm taking pics with my phone, sending it to my e-mail, and would like to attach the pics from there.
HELP!
HELP!
Upload it to a photo sharing site such as flickr, photo bucket, etc and grab the link from there.
It's not a performance car, and nothing you can do to it will make it one.
Premium fuel may increase your fuel economy slightly, but you'll still pay more per mile than if you use regular. It will make a little more power, but not much.
Cold air intakes mostly produce more noise, but won't measurably increase fuel economy and any increase in power is going to be at WOT, not in normal driving. Unless you drive at WOT all the time. At which case you should have probably bought something else.
If you want to put bigger wheels and lower profile tires on it and/or lowering springs on the suspension, refer to the second point. If you want to do it because you like the way it looks, have at it, but the primary result will be a worse ride in a car that was designed to be a luxury car.
Any mods you do will reduce the value of the vehicle to anyone but you.
Please don't put a fart can on it.
Enjoy your car.
rip out factory HU and replace it with aftermarket GPS/bluetooth/rear cam/ touchscreen ASAP. This is very easy to do! 1-2 hrs tops. (rear cam install will add more time but can be done in advance).
This will add a whole new dimension to the driving process (no need to fiddle with the phone, it autoconnects to your car once you get in, stream mp3's/ podcasts off of your phone, watch movies while driving 120mph in the break down lane (j/k) etc.) you will enjoy the driving process A WHOLE LOT more.
AND Do it all yourself for ultimate satisfaction!
As mentioned in an earlier post, the first thing you should do is make sure any required maintenance has been done, and if not, do it.
Enjoy your car.
Enjoy your car.
I purchased this car because of the smooth ride and overall lusury. I have no plans or desire to turn it into something else. I'm way past the age where I want to drive fast. I've driven the car for a week now and have no understanding of those who want to change this car from luxury to a hot rod or something other than what it is intended to be.
At this point, I will replace the lights (making them LED where appropriate inside & out) and tint the windows. I read about Seafoam on another thread so I just burned my first tank of gas with the Seafoam in it and at about 250 miles from when I need the oil changed, I will add some to the oil.
I'm somewhat afraid to use regular fuel. This car has a significant amount of miles and I don't want it to develop a knock or ping or whatever it is the owner's manual says will happen if I don't use anything other than premium.
I am DEFINITELY enjoying the car!
