Need Help Lexus es 300 2002
My AC light is flashing...what's problem? My shift indicator lights are out on console....how to fix? Thanks fo any advice.
Thanks going to look at the relay once my wife get back from shopping....probably won't have any money to replace......she has spent it all on Christmas.....
As mentioned by Hypervish, it could definitely be the relay, as those relays are known to go bad, but it can also be other things to, including being low on Refrigerant.
The relay is relatively cheap. Less than $20 at Autozone, etc.. So in this particular case it may be worth while getting another one and see if that solves your problem. If not, you'll need to look for the cause further.
Phil
Phil
Thank you for the help. Tried swaping another relay next to it and the light stayed on. Went to Toyota to get part...they wanted $81 dollars.....tried Autozone....$15 dollars......Well the light is still on and no longer blinking....Appreciate all the help. Hope I can provide some information in the future. Any need any information on tying flies....
Dr. B
Dr. B
