Squeaky Steering Wheel 2000 ES300
Old 01-11-14, 03:58 PM
westopill
westopill's Avatar
Post Squeaky Steering Wheel 2000 ES300
So this isn't a huge issue or anything, it's just a rather minor annoyance that I'm curious about. So whenever i take a slow turn, or turn the wheel all the way in one direction it tends to squeak and sort of moan. It actually sounds like a dying cat. Lol, anyways, i was just curious to see what you guys know about it and how to fix it. I know it's a common problem in these cars (mine is a 2000 ES300) i just don't know what to do about it.
Old 01-11-14, 04:08 PM
Received 3,025 Likes on 2,541 Posts
Put some silicone or similar grease between the points shown here:
muragrove (05-16-18)
Old 01-11-14, 06:35 PM
mlgbwk
mlgbwk's Avatar
wow nice. but how do I access this area? any panel to remove?
Old 01-11-14, 06:52 PM
westopill
westopill's Avatar
Ya, is there any easy way to access this or is the whole steering wheel interior portion going to have to be taken apart?
Old 01-11-14, 06:58 PM
You don't remove anything, it's right on the floor next to the gas pedal.
Old 01-11-14, 07:12 PM
westopill
westopill's Avatar
Oh, ok. Thank you very much for the advise! I'll give it a try when i got some free time and let you guys know how it went!
Old 01-13-14, 04:59 AM
hask
hask's Avatar
My car has the same issue !
Old 01-13-14, 08:53 AM
dlamb89
dlamb89's Avatar
I actually have this problem. Is WD40 OK?
Old 01-13-14, 09:56 AM
lostape45
lostape45's Avatar
Yes wd40 works great, I would say you have to oil it about every couple months but otherwise, no more moaning!
Old 01-13-14, 11:29 AM
PFB
PFB's Avatar
No, No, No. Don't use WD40. It is not rubber friendly, and will damage the Rubber boot. Use a silicone spay instead.
Old 01-13-14, 03:08 PM
Good advice, WD40 is not something you put on rubber. Plus it's a terrible lubricant anyway. Silicone paste has worked well for me, silicone spray works but the noise comes back. 303 Aerospace protectant should in theory work as it will bond to the rubber and make it slippery.
Old 01-13-14, 03:47 PM
01LEXPL
01LEXPL's Avatar
Lithium grease will do. Mine hasn't been back for over a year with some lithium grease spray I used
Old 01-16-14, 03:15 AM
lancefiles
lancefiles's Avatar
I came in here for the exact reason .....................thanx
Old 01-17-14, 07:38 PM
westopill
westopill's Avatar
I put some silicone spray on and it no longer squeaks! Thanks guys!
Old 01-17-14, 09:37 PM
mitmaks
mitmaks's Avatar
Common problem on Toyota's
Quick Reply: Squeaky Steering Wheel 2000 ES300
