Es 330 don't start or power
Hi
I am new to this site. I have a 2005 es 330
Yesterday day morning we started the car got out of our driveway. I notice all the warning lights are on even though the car is running.
I turn the key off. Then try to start it again. I was not able to start again.
The car was completely dead. When I turn the key to on I get check engine lt and that is it.
I chnage the battery and check all the fuses. I did not see any bad fuses.
I try to read the code for the check engine light, it will not read any thing.
No power to radio, windows , ac ,sun roof, dash and turning signals
I try to start in park and neutral . Nothing happen
Any ideas .
Any ideas .
Need more information.
When you start it, does it crank and not start or does not even crank at all. Battery has to have 12.6+ volts. Is the check engine light on? If so read codes with scanner.
Okay I found the issue
There is a 120amp fuse for the alternator
Thus was burnt.
I got the replacement from auto zone
Now I have a hard time putting it back.
One of the bolts that hold it that is under the fuse box, I can not get it in
Thus was burnt.
