Help p0022 code
Help p0022 code
2002 Lexus ES300 - 169,xxx miles Clean title
I need some help guys, this car is driving me crazy.
I had a P0021 for Camshaft position sensor Bank 2 too advance...
(this is an oreilys sensor)
I took it back and got it warrantied out for another one
Now i have a P0022 code, its the same code as the first one now its too RETARD ?
I've already cleaned out the Oil Control valve on both heads, i've replaced all 6 brand new coilpacks, i've replaced spark plugs. ive checked my timing belt and there is no slack or play in the belt.
i dunno wtf is going on !!!
CamelKool (10-24-20)
thanks for the response man... no one else seems to be of help at all on this forum.
update:
i went ahead and changed out the VTT for bank 2 (which is the OCV)
check engine light hasnt came on at all yet... so we will see if this first the gay *** p0022 code.
update:
CamelKool (10-05-20)
Hi! Please help me )
(Camshaft Position "A"
BANK 2
and a lot of misfare 2 4 6 Cilinders
can you help me?
What I have to do with this fault?
Thank you
Best Regards
Sergiy Strashko
Replaced:
1. oxygen upstream sensor
1. LEXUS Valve Assy Solenoid
Same bank as I had fault
the fault i had:
1. missfire bank 2
2. message Camshaft Position "A"
BANK 2
CamelKool (10-31-20)
