Inner tie rod replacement questions
Ok the inner tie rod and tie rod tool should be here soonish...
Some questions tho....
Will I need to replace the clips that secure the boot on the tie rod??? or are they reuseable??
Are there any other parts that I'll have to replace? - I guess the boot is a maybe I'll have to check it's condition when I get on with the job...
Can someone tell me if one of these adaptors (listed below) that come with the tie rod tool will be the right size for removing the Toyota / Lexus inner tie rod???
Includes 7 Adaptors • SAE: 1-3/16in, 1-1/4in, 1-5/16in, & 1-7/16in • Metric: 14mm, 17mm, & 33.6mm
Any hints, tips, or advice before I get started???? This is not a task I've attempted before...
From what I gather you should count the number of turns / threads it takes to remove the outer tie rod from the inner to keep the alignment good enough to drive to the tyre shop for an alignment afterwards....
I've got a couple of stands to lower the car onto when I jack it up...
Do I keep the wheels straight for the job? or do I turn them to the passenger side as I'm doing the drivers side...??
How do you "unstake the claw washers"??? or will that be obvious when I see them?? Is it difficult???? How do I restake the washers?? or is it also obvious when I get to that?? should I be using locktite or some other similar product for any part of the job??
You can reuse them if you are able to get them off without damaging them. The threads get gunked up so clean them up and lube first.
Yep check the boots and of course replace the outer tie rods.
Don't know, I use a crescent wrench or sometimes a large pair of Vice Grips. The proper tool would be nice...
Yes. There is a specific measurement shown in the service manual, but I don't bother with that. If the alignment shop is only a few kilometers away as long as you have the wheels reasonably straight no worries. Put some grease or anti-seize on the threads.
You can turn the wheels to whatever position gives the best access.
With whatever you have available. I have a punch of some description that I ground down to a more flat end, I use it for various jobs.
The hardest part of this job is lack of access, it's much easier when the car is on a lift.
gtstcactus
02-12-14 10:07 PM
GS714
CL of Southern California
09-15-12 11:21 PM
