97-00 Camry/Solara Coilover sleeves on a 98 ES300?
Would they fit on a 98 ES300?
http://www.sparktecmotorsports.com/gc-8053-01.html?utm_source=googlepepla&utm_medium=adwords&id=20861070197&utm_content=pla
I'm not 100% but I am pretty sure that they should. The ES300, Camry v6 (and I think camry in general), Avalon, and Solara are pretty much the same car. I would wait for someone a little more positive than I am to answer, but I would think that they would.
Yeah those should fit, mechanically we have the same suspension as a Camry.
Keep in mind, since you are going to a system that allows you to pick and spring rate and length and set height, you need to tailor the height and spring to the shock you use. The stock stuff is too soft if going low is your plan. There is no "good" sport shock for this car, but some of the aftermarket options are a bit sportier, the Tokico blue is probably your best bet here. It will let you go lower and use the stiffer spring you need to do that without killing your ride by bottoming out constantly.
dm1104
13
10-20-14 09:02 AM
