Please help 97 lexus es300 rear lateral link bolts
Old 03-04-14, 01:03 PM
Tutu1
Tutu1's Avatar
Default Please help 97 lexus es300 rear lateral link bolts
Im new on this website and i want to knw if someone can help..
The lateral link or lower arm N1 and N2 bolts.
I want to knw if someone knws how to remove them i did remove one but the one next to the tire is stock and i cant pull it out someone help please
I took the nut out but the bolt i cant
Here is a pic so u guys can see what im talking about
Attached Thumbnails Please help 97 lexus es300 rear lateral link bolts-image.jpg
Old 03-04-14, 04:12 PM
Tutu1
Tutu1's Avatar
Anyone????
Old 03-05-14, 04:59 PM
01LEXPL
01LEXPL's Avatar
The bolts are long, about 9" in length. There is four of the same, the two in middle and two outers by the rear hub.
I got mine from the dealer when replacing them (two sized so they were cut off) two were re-used.
8$ each. Good luck.
Old 03-06-14, 11:19 AM
Tutu1
Tutu1's Avatar
Yea but the 2 that are by the rear hub are stock i cant take them out.. Do i have to cut them??
Old 03-06-14, 09:21 PM
01LEXPL
01LEXPL's Avatar
^ Did you see what I wrote?
Cut them out. Get new ones. Re-install.
They rust inside the shaft, the metal expands. Heating them doesn't work.
Old 04-05-14, 05:59 PM
Tutu1
Tutu1's Avatar
I cut the bolts but i cant take them out.. I try drilling them out but nothing any ideas??
Old 04-06-14, 01:17 PM
nwa320drvr
nwa320drvr's Avatar
Try spraying with Parts Blaster (PB) or other penetrant and use a steel drift and hammer to punch it out. It's likely frozen in the bushing and will require quite a bit of effort to remove.
Blkexcoupe
Suspension and Brakes
01-29-17 01:17 PM
scott101
15
05-14-13 11:42 AM
lexy2013
03-24-13 10:31 PM
Amo
RX - 1st Gen (1999-2003)
04-04-08 06:45 PM
Quick Reply: Please help 97 lexus es300 rear lateral link bolts
