2000 es300
It's idling bad and cuts out driving on the interstate, get off the pedal get back on and it picks back up for a little while and does it again. Any clues where to start???
It could also be the EGR or a bad oxygen sensor. Any codes?
Read this thread:
https://www.clublexus.com/forums/es3...0-surging.html
Start with the basics, throttle body cleaning, new spark plugs, fresh air filter and maybe some fuel injector cleaner.
Read this thread:
Don't forget the IACV, and might as well do the PCV valve while you're mucking around if you haven't already:
https://www.clublexus.com/forums/rx-...-write-up.html
https://www.clublexus.com/forums/es3...ve-1mz-fe.html
darrell722
09-06-15 06:18 PM
