swaying in turns
I think my sway bar or link is damaged. when in corners the back of the car sway like floating on ice what is it. the lexus dealer wants starting 125.00 to just look at it. is there a place cheaper to pin point the problem
Our 94 ES started having the same handling problems at about 150,000 miles. On sweeping wide turns, it would feel like the rear end was not staying in line with the front end. Also, there would often be a delay between steering input and directional change when making sharp turns. Sometimes, there would be a slipping sensation in the steering wheel when making turns.
It turned out that the problem was a worn steering rack. After replacement of the original rack with a remanufactured rack, the steering was as good as new.
A good alignment shop should be able to diagnose the problem.
had sway bar and link and bushing checked (nothing)
readjusted tire pressure rotated tires. still swayinghttps://www.clublexus.com/forums/images/icons/icon4.gif
