can a camry trd muffler bolt-on work on es?
i want to make some mods on my ride, nothing too serious. i dont want to ruin the warranty. i opted for the 5 year 100,000 mile warranty and it sure is worth the extra couple of bucks! just recently i had the front struts, springs, and engine mounts replaced by the lexus dealer under warranty free of charge! as for the trd muffler, id seriously consider buying it if it bolts on easily on my es. trd supercharger would be NICE, everyone talks about it, id be ego trippin if i was the first one to pull it off. not likely, maybe in 5 years id be rollin in a lexus is 500 6 speed or something...
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
the camry is pretty much a lexus. as long as it is in the same year it will fit ur ES. i got a 93 ES and i found 2 exhausts that would fit, but i only found them by lookin up a camry with the same year. my dad is a mechanic with lexus n says it works. his name on here is franksES.
Lexus Connoisseur
There is no specific exhaust system for the 92-93 3VZ-FE motor unless you go to the japanese catalogs and search for them. You would have to go with an aftermarket universal application unfortunately. The TRD muffler is designed for MCV20 97 and up 1MZ-FE applications. Same goes with the S/C. It's only for 97 and up 1MZ-FE non VVT-i models. The 3VZ-FE is a totally different engine from the 1MZ-FE.
http://www.spiderautomotive.com/spid...osforcam1.html
here is a website with an exhaust for a 92-96 camry. they have the 2.2l 4 which wouldnt be the same fit as the lexus but they also have the 3.0l exhaust which does fit.
http://bosalperformance.com/catalog/...aders_cat.html
here is the 2nd website i found that will fit a 92-94 camry v6.
Lexus Connoisseur
well actually... i'm not sure how much the air intake area actaually changed. they basically just increased the hp a bit, and the 1MZFE was made of aluminum... that's all the difference i know of.
Lexus Connoisseur
