Sunroof Problem
Having trouble with the sun/moon roof of my 2002 ES 300. Worked perfectly fine till I replaced my battery in the car. Any help will be much appreciated!
What exactly do you mean? Does it not work at all or does it work but no longer automatically opens or closes?
If its the latter, you need to reset the sliding motor whenever disconnecting the battery (or replace in this case). If not, the AUTO operation and jam protection function will not work.
Reset sliding roof drive gear (motor)
1. Set the sliding roof glass in the fully tilt−up position.
2. Push and hold the sliding roof switch UP until the sliding roof tilts down a little.
3. Check that the sliding roof tilts up/down and slides open/close in the AUTO operation.
Hint: If the sliding roof is not in the correct position, press and hold the sliding roof switch UP and CLOSE until 10 seconds have passed after the roof stops moving or starts the reverse operation. The reset operation will be completed once you've done this.
If it doesn't work in general I'd possibly suspect a fuse issue.
Hi,
I have a Sunroof problem with 1997 es300, i am not able to close it , it is in the tilt position.
Please help me to close it.
The fuse is good .
The fuse is good .
