Rattling noise in front end when driving over small bumps?
Old 04-28-14, 08:54 AM
Hayk
Hayk's Avatar
That's a pretty bad crack in that picture. Unbolt it and inspect the part. As mentioned before, you do not need to support the engine, it simply sits in place.
Old 05-18-14, 09:48 AM
PDXLex
PDXLex's Avatar
Originally Posted by artbuc
Yes, that is it. Can you tell if it is a surface crack or does it go all the way through?
Artbuc, it's definitley cracked all the way through (see pic below). I took the dog bone out today and put a new one in. It was a relatively cheap and simple job. It cost $40 and took about 15 minutes of my time. It seems to have solved one of the rattles I heard in the front end. The remaining noises appear to be the strut mounts, which I'll be tackling when I replace the struts next month. Thanks again for everyone's advice on here!
Attached Thumbnails Rattling noise in front end when driving over small bumps?-image.jpg
Old 05-21-14, 08:01 PM
umbro7267
umbro7267's Avatar
Is this something that an 04 would have a problem with?
Old 05-22-14, 08:30 AM
Hayk
Hayk's Avatar
It's worth checking. A lot of FWD Transverse engines come with a "dogbone" mount.
Old 05-22-14, 10:07 AM
umbro7267
umbro7267's Avatar
i looked around this morning didnt really see anything that look like that, turned out i was busy trying to make sure that i had the bottom nut tight on the sway bar which lead me to not tighten the top one which made a lot more noise
Old 05-28-14, 10:17 AM
chriswiss
chriswiss's Avatar
Did the dogbone mount line up properly when it was changed? I'm asking because I just looked at mine and there's nothing left in it. I just picked up a new mount.
BC93
ES - 5th Gen (2007-2012)
30
08-18-17 03:14 PM
ricomr
GS - 1st Gen (1993-1997)
06-17-08 01:37 AM
Ariyanna
10-26-06 06:26 PM
642jdub
05-09-04 09:38 AM
bigsax
01-23-04 09:53 AM
Quick Reply: Rattling noise in front end when driving over small bumps?
