Definitely time for a transmission fluid change, right?
Since we're on the subject of transmissions...anyone want to give their two cents on these: magnefine filters ? I've heard good things, but also have some hesitation about 'completely' cleaning the fluid at once, just like trying to switch an older car from conventional to synthetic oil, and how that can make leaks 'appear'.
I'm sorry guys, I have an 01 ES with 155K and I want to do a drain and fill on my trans. I am just confused on exactly what you do. So I see the 10mm bolt on the trans pan underneath the car, and I know you drain from that, but where do you put the new fluid in? Is it through the dipstick or am I not seeing the trans fluid resevoir cap. Any tips appreciated, thanks.
And to add to the synthetic oil, I switched over at about 140k and had a few minor leaks for about 2-3k at first but after that there havent been any issues.
Make sure you check your fluid level before draining. And measure how much of it comes out.
So, update on my transmission. It actually does still seem to have a slight second or two delay switching from Park to Drive or Reverse. Sometimes I think I'm hearing a slight whine at lower speeds but I'm not sure it's from the tranny. The guy who test drove it said it seemed to shift fine, but there was a leak. I called back the next day and inquired about that, and apparently the leak must have been from the pan gasket which was replaced, and the magnets supposedly did not have an alarming amount of metal shavings. I know if they found something they could make money on they would've told me, but I wanted to call and make sure, since I forgot to ask. I'm gonna try to do another drain and fill or have it done again soon. Praying this thing lasts!!
That delay may just be low line pressure. Line pressure can be tweaked a little by adjusting the kickdown cable which is the second cable on your throttle body. There is a post about it somewhere in CL... Here it is!
https://www.clublexus.com/forums/es3...-shifting.html
So you know the cap on your power steering reservoir reads "use Dextron II or III" Regular PSF kills Toyota, Lexus, and Nissan power steering systems all the time! If you have added PSF, don't panic. Just drain and fill it a few times with the correct ATF. I use a small hose to siphon the fluid out when I run into this on customer cars, and it happens all the time. Did the AAMCO guy look for a build up of clutch material sludge in the pan? A little metal is nothing to be concerned about, but clutch friction material is.
Yeah, I knew about the steering fluid being wrong. I guess the previous owner was using regular PSF, so that's thoroughly through the entire system already, and I haven't flushed it yet, so I'd been using Lucas PSF (supposedly compatible with all PS systems)... I've been told that if I mix ATF with residual PSF from a simple drain of the system, it could gunk up and make things worse. It had/has a leak too, so I started using Lucas stop leak and it kind of seems to be slowing. The previous owner said he replaced all power steering hoses but not the pump. I'm not surprised if using PSF is killing it. Hopefully just the pump and not anything else. I know I'll need that eventually. Not sure about the sludge from the tranny, but it seems to be working fine. I've driven almost 300 miles in the last two days, mostly freeway/highway with no issues. Timing belt / water pump job went fine. The mechanic says the old one didn't even look too worn. Go figure. But my radiator is leaking now too. I knew I had a coolant leak but I was hoping it was just a hose. Oh well. $170-200 more, that sucks but whatever. I'm trying to get it all done little by little. My suspension is so shot I'm scared driving over storm drains. Haha! It's getting me around though. This car has been used and abused (yet sort of maintained minor maintenance wise) and it just keeps on chugging!! I hope...
dsigala
15
06-20-15 11:49 PM
ALLCHILL
12-09-14 02:50 PM
