EGR valve
EGR valve
Anyone know where the EGR valve is located on a 2001 es300? I would like to clean it. What's involved in removing and cleaning it?
Thanks
Thanks
I do have the label, and it does show an EGR system, but does not give locations.
ALlDATA, to which I subscribe, is of no help in this case either.
Can someone please confrm if the 2001 es300 has an EGR valve or not.
I was planning on cleaning it, as preventive maintenance, but if there isn't one than I guess there is nothing to clean.
Thanks
I looked it up on TIS and couldn't find a single document for the 2001 ES 300 regarding EGR valve. Thats as close as I can say to there being to EGR on your car. I haven't been under the hood of an 01 so I can't say from personal experience or knowledge.
Contrary to my reply, I checked my emission label again and there is no mention of an EGR valve. So no wonder that I can't find one.
Thanks
Thanks
The EGR 's job is to reduce NOx. Exhaust gasses mixed in with the fresh air/fuel mixture lowers combustion temperatures. High temps = more NOx. So by the system being able to control the valves, it can simply close the valves early. Leaving behind some exhaust gasses to recirculate.
The EGR 's job is to reduce NOx. Exhaust gasses mixed in with the fresh air/fuel mixture lowers combustion temperatures. High temps = more NOx. So by the system being able to control the valves, it can simply close the exhaust valves early. Leaving behind some exhaust gasses to recirculate.
Thanks
