Longevity of coolant hoses??
How long do the coolant hoses "normally" last on these cars? I am going to do a timing belt/water pump and I wonder if I should change ALL the coolant hoses since the system will be drained.
The car is a 97 with over 225k miles..... They appear to be in decent condition for their age.
The bypass hose looks like a ****** to change.
Any thoughts?
Any thoughts?
The upper rad hose usually goes first, the coolant bypass is unpredictable but they do tend to fail. You could go ahead and replace the upper and lower radiator hose as a set, the rest I would leave alone unless you see signs of leakage.
The bypass hose is not that hard to replace.
I read many Lexus/Toyota forums on a regular basis and I have never heard of a by-pass hose failure. To the contrary, most people, including myself, have replaced it while there for other reasons, eg VC gasket replacement, and found the original hose to be in near perfect condition.
Thanks for all the suggestions! I am going to change ALL the coolant hoses as a preventive measure just because the "Red Juice" will be drained while doing a TB/Pump and at $30 a gallon for anti freeze, I think I will be proactive and spend the extra money (~$100) and time on this "hoopty project" and have peace of mind while my son uses it at college.
Any suggestions on doing a bypass hose change?
PFB
03-13-17 04:51 PM
