drain/fill, how do you check 05 ES level later?
Old 05-10-14 | 09:10 PM
pauloil's Avatar
pauloil
Default drain/fill, how do you check 05 ES level later?
I have done 3 drain and fills of tranny, 3.7 qts. each time. well this time I checked level on a 75 degree day after driving up the corner and back, and level was 1/4in above minimal mark. so it got me wondering if there is a way to say, drive the car 10 min on a 60 degree day and it should be halfway between min. and max mark, etc. so how are you supposed to get a good check of the tranny fluid level?
Old 05-11-14 | 06:35 AM
hypervish's Avatar
hypervish
Drive it a good 20 minutes, ensuring that you have gone through all the gears (and locked the converter at some point), then leave the engine running and in park. You should get a solid fluid reading.
Old 05-11-14 | 07:19 AM
brucelee1's Avatar
brucelee1
Yes, either you check it dead cold (bottom mark) or HOT (top mark).
Either should work, I prefer HOT.
Old 05-11-14 | 11:21 AM
BDSL's Avatar
BDSL
Read your owner's manual. It tells you how to check fluid level.
Old 05-11-14 | 03:11 PM
pauloil's Avatar
pauloil
I checked after my wife came back from church, and it was in the middle at 77 degrees. here's the gasket:
http://www.fcpeuro.com/products/volv...s80-v50-v70-xc
takes a 10mm hex for the drain plug, and what I did was leave about 283 mL left in the first bottle of T4 to get the 0.7 qt in, and then 3 more qts.
my owner's manual had zippo in it.
iluvny
05-08-14 01:46 PM
ViPeRs103
11-29-10 08:44 PM
Lexguy026
Maintenance
08-30-04 07:18 AM
sunman
Maintenance
08-28-04 01:01 PM
1UZFE
12-11-03 08:54 PM
Quick Reply: drain/fill, how do you check 05 ES level later?
