Stop and roll chokyness ,loud crack / pop noise
98 es
Car seems to be under stress when first accelerating from a stop if you press slightly harder than soft , merging off the high way at 40 mph roll gave it a nice push of the gas and the car shook abruptly forward and back motion same
Chokyness as when at a stop and you give it a nice push (half throttle) sometimes you'll feel and hear a crack popping noise right on the left center of the car...I've changed spark plugs pcv valve spark plug wires catlytic converter and all engine mounts , only thing I can think of is changing the fuel filter ... How do I check to see if one oft injectors are bad or where should I take the car to figure out the problem by computer is there a computer that can read my fuel injectors working properly ??? Read my last post to see the story behind this. I swear to this day that gumout was the cause of all of this nonsense I can't sleep at night. I am miserable. The car is the only thing I had going for me
