Hydraulic Cooling Fan Assembly
Old 05-18-14, 11:46 PM
Wahlnutz
Wahlnutz's Avatar
Default Hydraulic Cooling Fan Assembly
Hello. Recently my car has been overheating. My mechanic has replaced the radiator, thermostat, and is now replacing the temperature sensor. He thinks it's the hydraulic cooling fan assembly. I've been doing research on the price and it is quite high around 500-600 dollars. Does anyone know where I can get one for any cheaper if the new sensor doesn't work?? Or if anyone has an suggestions on this matter. Thank you in advance.
Old 05-19-14, 06:59 AM
Hayk
Hayk's Avatar
I would find a better mechanic, sounds like he's a parts changer.
Old 05-19-14, 09:09 AM
Received 3,020 Likes on 2,536 Posts
I agree this mechanic sounds like he's throwing parts at the problem go somewhere else. Testing the hydraulic fan is VERY simple I guess your mechanic didn't bother to look in the service manual. See this post on how to test the fans operation.
Old 05-26-14, 12:53 AM
Wahlnutz
Wahlnutz's Avatar
Well he tested the fan with the jumper cable and nothing happened any other ideas? Also it's good he did these things because changing the thermostat for sure helped.
Old 05-26-14, 04:53 PM
Make sure the connector on the PS pump is secure and not damaged.
Old 05-29-14, 08:29 PM
Wahlnutz
Wahlnutz's Avatar
Okay so sensor has been changed and still overheating!! The fan won't go on high and the connector is fine. I am stressing out please help! Also the mechanic is a good guy and charges very little so plz don't diss him.
Old 05-30-14, 02:02 PM
Does the fan turn slowly? The nature of this system is the fan is always turning even when the engine is cold. If your mechanic really thinks it's the fan then source a used one. BTW if the connector is removed from the sensor on the thermostat housing the fan should run at full speed. There is a control module on the right side of the car under the dash but I highly doubt that has failed although possible.
Which sensor?
brendam24
12-25-14 01:58 PM
Murphydurf
GS - 1st Gen (1993-1997)
08-15-13 05:52 PM
ancdmd
03-19-12 08:08 PM
fusion49
Performance & Maintenance
11-15-07 08:01 PM
Quick Reply: Hydraulic Cooling Fan Assembly
