clear corners and tail lights
Old 02-15-03, 03:46 PM
jdoballer
jdoballer's Avatar
Default clear corners and tail lights
just wanted to know if anyone knew where i could get some clear corners and clear tail lights.I have a 96 ES 300 and would like to start upgrading it with those first. thanks.
D
Old 02-15-03, 04:24 PM
squarehat
squarehat's Avatar
Welcome to ClubLexus. I, too, own a 1996 ES. There are no companies that sell pre-made clear corners and tails for the 92-96ES. The front corners are a fairly easy DIY mod, a lot of people on this board have done them, and then it's possible with some patience to remove the amber from the tails. If you use the search and search the ES300 forum for "clear corners" you should find some good how-to's, pictures, and read about any difficulties people have had.
Old 02-17-03, 10:11 AM
LEXBERG
LEXBERG's Avatar
http://www.autodynamic.com
Old 02-17-03, 10:26 AM
Kyle Harty
Kyle Harty's Avatar
Welcome, hope we can help you with any questions you've got.
I've done both front and rear signals on my 92 (pretty similar to 96), the headlights are pretty easy. The taillights are tougher, they're alot more fragile and a little tougher to get apart. I used the oven method on both. I think it's worth it if you take your time and be careful not to break the lights. IMO, it freshens the look of the car a little; but I do think the clear corners look better on the earlier models without the darkened pieces inside the headlights.
Like squarehat said, a search should yield alot of good info and pictures to help you decide what to do. There are a few pics of the corners in the link in my signature, page 3 I believe.
Old 02-18-03, 05:35 AM
jdoballer
jdoballer's Avatar
thanks guys i'll try out and that link has some clear corners for a 97-99 i might see if i can get them to fit on my 96.thanks again.
D
Old 02-20-03, 09:57 AM
Kyle Harty
Kyle Harty's Avatar
The 92-96 ES headlight and turn signal assembly is all one piece, you can't replace just the turn signal section. The DIY method is currently the only way to go, unless you can find someone selling a pair they've already done on E-bay or in the classifieds here.
Old 02-21-03, 04:30 AM
jdoballer
jdoballer's Avatar
thanks kyle i wasnt sure if they were all one piece im just starting to work on my car so i appreciate all the you guys can give me thanks again.
D
heidihidin
ES - 5th Gen (2007-2012)
04-05-18 02:46 AM
ScottURnot
SC- 1st Gen (1992-2000)
31
10-06-04 08:22 PM
shoyu
Lighting
02-09-03 05:59 PM
BigRich
Lighting
21
05-08-02 06:29 PM
Quick Reply: clear corners and tail lights
