Video of my problem that ive been threading
Old 05-26-14, 09:37 PM
bloodyj410
bloodyj410's Avatar
Default Video of my problem that ive been threading
LISTEN LOUD WITH SPEAKERS OR YOU WONT NOTICE
^^^^^^^^^^^^^^^^^^^^^^^^^^^this is sitting idle after rpms lowered i put it into drive and held the brake and this is the chokyness /sound that i get while accelerating that ive been threading about... this same change of engine note in the video is the chokyness /lossof power during acceleration ,
my guess is a dying coil? could that be this change in note?
I BELEIVE THESE CODES HAVE NOTHING TO DO WITH THE ISSUE, HAD THE 02 CODE SINCE I BOUGHT IT , AND CHANGED THE CAT EVER SINCE IVE HAD THIS ISSUE IN RPMS, THE COOLANT SENSOR CODE IS NEW AND WASNT THERE EVEN WHEN PROBLEM WAS OCCURING A WEEK AGO ONLY CAME ON AFTER I CHANGED THE FUEL FILTER
LISTED CODES :PO135-O2 SENSOR BANK 1 SENSOR 1
PO125- COOLANT ,
Old 05-26-14, 10:25 PM
PuReChaos
PuReChaos's Avatar
What ever happened with Toyota, what did they tell you when you brought it in for diagnosis a while back?
Unfortunately, I can think of a few tests you could do, however, they require the use of a scan tool. Honestly with how constant the sound is, I would suspect misfire, but then again that brings the question of why is there no codes for it yet. I'm a little stumped as to what information I can offer you if everything has been tested that was mentioned in previous threads.
Old 05-26-14, 10:42 PM
Received 2,913 Likes on 2,457 Posts
Old 05-26-14, 11:04 PM
bloodyj410
bloodyj410's Avatar
ive seen that video
never took it to toyota because i figured they would charge 100 an hour and this would take hours and hours of diagnosing im real short on money right now and scared to drive much
Old 05-26-14, 11:11 PM
Apply what you learn in that video. You can at the very least do a resistance test on the injectors when cold and warm. If for some reason you're not able to do some basic tests then don't start throwing parts at the problem get a proper diagnosis. It will probably save you money. BTW the temp gauge in your video is that as high as it goes?
Old 05-27-14, 01:10 AM
bloodyj410
bloodyj410's Avatar
temp guage gets to notch 6/7 when running temp
MYTOYLEX
07-08-13 02:26 AM
groundzer0
Performance & Maintenance
02-12-13 06:48 PM
Cling
13
01-24-11 04:09 PM
Project2jz
IS - 1st Gen (2001-2005)
10-28-10 07:42 AM
Tomek350z
RX - 1st Gen (1999-2003)
08-11-10 05:46 PM
Quick Reply: Video of my problem that ive been threading
