2004 ES330 Brake vibration
I have a 2004 ES330 that had a vibration while braking. I replaced the pads and rotors and had the wheels rotated, balanced and aligned and I am still getting the vibration, especially at highway speeds while braking. I do not have any faults that are showing up. Any ideas on what could be causing this?
I have had all of the front end and suspension parts checked and had the tires balanced on the car and everything is tight with no vibration until I step on the brakes. I also had the new rotors checked for run-out and they are all within spec. This problem was there BEFORE I replaced all of the parts. I was thinking about pulling the ABS 50 amp fuse to see if it is a ABS problem. Any thoights on doing this?
BossGS4
Suspension and Brakes
19
07-16-09 07:25 AM
