Hooking up a sub/amp leaving stock the same
Hi I'm probably going to have a friend help me but i was wondering if it is possible to hook up a sub and an amp to the stock stereo. Leaving the stock amp and speakers the same. I believe its not that nakamachi.
1999 lexus es300
Thanks
1999 lexus es300
Thanks
Awesome so I just splice to the front left, front right 6.5 door speakers?
Power, Ground,.... All that is left is the blue wire, what do i do with that?
Cig lighter fuse probably?
This will work right?
http://www.walmart.com/ip/Scosche-Li...ntrol/31954500
I'm a little suspicious of buying the boss converter that keeps on popping up everywhere when I search for one.
Yes. I spliced directly from the amp because its a lot easier to access the wires. This is the exact one i used http://www.ebay.com/itm/Rockford-Fosgate-RF-HLC-2-Channel-Car-Audio-High-to-Low-Speaker-Converter-New-/400710552979?pt=US_Signal_Processors&hash=item5d4c35cd93&vxp=mtr , https://www.clublexus.com/forums/es300-and-es330/129035-es330-300-diy-do-it-yourself-and-technical-tips-4.html and i used this post to guide me on which wires i needed to splice into, post #60.
I attached them to the rear speakers, instead of the front? Is there a difference?
Also the subs are not as loud as expected, is this because the choice of setup I have used?
Or maybe I just need a stronger amp.....
Kurtis916
04-28-15 02:58 PM
QuachmanES
05-13-10 05:02 AM
acenase
10-31-07 01:05 AM
labtec
05-26-07 07:57 PM
SCguy58
04-17-06 07:32 AM
