Replacing tail lights with LEDs?
Hi I was wondering if it was possible to replace my brake lights, turning signals and reverse lights with LEDs?
I was thinking something like this would work?
http://www.superbrightleds.com/morei...wer-leds/1821/
It is dooable but be aware that this will cause your bulb out warning light to come on, and your flasher relay to misbehave.
There are LEDs with resistors built in to eliminate this issue, or you'll have to wire your own resistors.
Others, that have actually done it are sure to chime in. Changing the license plate lights however is not an issue.
Phil
Phil
A timely topic, I have been considering doing this as well. I have already changed my license plate lamps out and the result was amazing. I used these bulbs here: 1pcs Warm White 5 x 5050 SMD LED. These also work great for the courtesy lamps in the front doors and the rear side marker lamps as well, though the red ones are better: 1pcs Red 5 x 5050 SMD LED. I can post some pics later once I get the car back from the shop, they messed up the rear valve cover gasket it would seem.
Alright doesn't sound too difficult.
I'll be doing a lot of googling but would this resistor work?
http://www.superbrightleds.com/morei...r-kit/190/831/
Any opinions?
Any opinions?
I put in a 7443 tail light bulb to compare to the incandescent stock bulb.
While the LED bulb was bright, the optics inside the lens causes it to show dimmer as a brake light compared to the incandescent. Not to mention the blown bulb warning light on the dash.
The only advantage was a faster transient time and redder light from the LED.
Here's a full video review comparing the two:
LED vs Incandesent Tail Light Bulb Review - YouTube
navi243
03-01-15 11:54 AM
