Transmission Bolts
Old 06-15-14, 12:02 PM
greens6
greens6's Avatar
Default Transmission Bolts
Hello,
I have a 2000 ES300, Platinum with about 150K mi. I just changed my ATF and found that a bolt near the drain pan is missing! Not sure how long. I was wondering if someone can point me in the right direction in determining the correct P/N for this bolt. I attached a couple of pictures.
I appreciate any help with this. I cannot seem to figure this out from the drawings I find online.
Thanks,
greens6
Attached Thumbnails Transmission Bolts-img_0272.jpg   Transmission Bolts-img_0276.jpg
Old 06-15-14, 04:43 PM
Received 2,826 Likes on 2,389 Posts
Take a look here maybe you can spot it. You sure there it not a bolt head on the other side it kinda looks like there is in the one pic. Either way the bolt is most likely either an M12-1.25 or M10-1.25 not sure the length but around 50-60mm.
Old 06-16-14, 02:16 PM
greens6
greens6's Avatar
Thank you! I will take a look.
YODAONE
11-22-17 06:37 PM
PlotPoint
01-13-13 03:50 AM
MicahBerry
28
01-28-12 05:27 AM
xzeus
Performance & Maintenance
06-14-09 08:19 PM
Quick Reply: Transmission Bolts
