Radiator fan
For some reason my car only fan only when ac is turn on. Most of the time the fan never run and usually boil up the radiator cap. Recently i disconnect the bottom radiator engine coolant temperature sensor wire and it would run since then. Yesterday i use the paper clip to test the bottom one and the one on the driver side. It would run so my problem is that i changed from the themostat,and both coolant sensor. What can be wrong with it
