ES330 2004 to 2005/6
Trying to update my steering audio controls(currently don't have), backup camera and a fer others toys. But I keep running in to an issue were there was a mid year design change on the ES330. My car was built in Jan 04, the change took place June 04 I think factory location changed.
Does anyone have the wisdom and or knowledge to know what changed ? My interest is with;
OEM NAVI,
ML, ML has been upgraded to the 2005 model (0W101 ?)
6 CD)
all I want is to add Audio controls to my steering wheel
Ok
All I want to do (also) is ad a backup camers trying to post pics.
Am I in the correct forum ?
Any help would be thankful.
OEM NAVI,
6 CD)
Ok
It's definitely possible to add a backup cam. The easiest way is with a wireless system, there are plenty on eBay if you just want an inexpensive way to do it.
As I said in your last thread, I don't think the steering wheel controls are a good use of your money. Even if you find a newer wheel (not cheap), the later ES 330s may (probably) have another wire or set of wires that your car doesn't have for these controls.
If I was going to sink about 500 bucks into my car's interior right now, I think I would start with the speakers.
How many more threads are you going to make?
https://www.clublexus.com/forums/es3...-2005-6-a.html
https://www.clublexus.com/forums/lex...30-w-navi.html
https://www.clublexus.com/forums/es3...heel-swap.html
https://www.clublexus.com/forums/es3...-on-es330.html
https://www.clublexus.com/forums/es3...ringwheel.html
https://www.clublexus.com/forums/lex...-1500-toy.html
https://www.clublexus.com/forums/lex...wheel-dyi.html
Forum members have some good suggestions to modify an early build 04 ES330, you don't, but do have a lot of spare time to count other members activity and their technical ability, you apparently don't.
I thank all the other members for adding some good ideas, speedkar9 get a life
Makomagnet
08-09-14 10:55 AM
