3es Screeching tires during certain turns, but traction's fine, dry and wet roads?
Old 10-08-14, 08:29 AM
dlamb89
dlamb89's Avatar
Default 3es Screeching tires during certain turns, but traction's fine, dry and wet roads?
So I tried searching the forum prior, didn't find a post that was relevant enough to my situation. Whenever I have a sharp-ish turn at a decent speed, the tires slightly screech. If the road pavement is rich and new, it will barely happen, but will still occur. On older roads, it tends to be way more present. She handles great, which I don't understand. It grips the road just fine, during the screeching turn or not. OEM struts in front but still good, rear struts are KYB and the dist links were replaced along with it. Haven't done anything to the control arms, they seem fine, but she seems to tilt slightly more than it should during sharper turns. tires are inflated and fairly new. I did a bit of outside research (google) and found it could be an issue associated with the power steering, or the PS pump. Any input would be really appreciated, as I hope my steering or traction won't go out during driving with this issue
Old 10-08-14, 09:26 AM
Hayk
Hayk's Avatar
What tires do you have?
Old 10-08-14, 09:43 AM
dlamb89
dlamb89's Avatar
Goodyear, not sure about the model. Either integrity, or assurance.
Old 10-08-14, 10:57 AM
BDSL
BDSL's Avatar
Is your PS pump / fluid / belt any good?
Old 10-08-14, 11:19 AM
dlamb89
dlamb89's Avatar
fluid is fine, belt has been replaced recently. pump itself seems fine. The only other issue that could be somewhat relevant at all is how my steering became rough in a weird way (thread here: https://www.clublexus.com/forums/es3...ater-gone.html ).
As noted, the steering issue never occurred again, however this screeching issue remains.
Old 10-09-14, 04:26 PM
Mythotical
Mythotical's Avatar
Go to a tire shop and get a free alignment check, I bet that is your problem.
Old 10-16-14, 06:09 AM
jltait
jltait's Avatar
Not having heard your particular screech, I believe those types of sounds could potentially be made by a bad CV joint as well. Check to see you don't have any torn boots on your axles.
Old 10-17-14, 09:30 AM
dlamb89
dlamb89's Avatar
thanks for all your input. i overloooked that the PS fluid was old/dirty. Threw in new fluid and the problem seems to be gone. Thanks again, I'll check my alignment and CV joints just to be sure and see where they're at. My other post still remains (bad city mileage good highway), waiting on a new phone to record a video.
Matodorosa
05-31-15 06:08 PM
jlawr
02-11-13 02:50 PM
Fizzboy7
11-28-08 01:17 AM
bam
02-06-06 08:35 AM
Quick Reply: 3es Screeching tires during certain turns, but traction's fine, dry and wet roads?
